When I was referring to "open loop", I was talking about the first few minutes after starting my motor. I was surprised that it was so lean? Maybe that's why it seems to search for idle for the first few minutes? After warming up, it idles and cruises in the range that I would consider within spec. Not that I know much about this stuff... I'm learning as I go :-)
The second thing was wide WOT. I was referring to how rich it ran when I floored it.
It's an Innovative MTX-L wide band sensor. I'm currently only using it for monitoring the motor. The stock ECM has no connection to the sensor.
I hope to install the MS3 on the motor this weekend and get more into the "weeds" of tuning this thing. The motor is currently stock, but a little cam, heads and TPI are a short distance away. If this MS stuff works out, I'll use it to run my LS/4L80e combination that's going in next spring.
