Dont think so lol. Would have to go find it. Do you need it?Your dad using that diff cover he took off of that burnt truck at hidden falls? Think it was a moroso with the bolts to support the bearing caps.
You’re prob right. Just going to leave it on for now we can cut it later if we need to.Going to take that pinion snubber bracket off the frame? Won't do anything now.
Martin
We went 2.5” lift and was told that would be enough. Guess we will find out when we start putting it together. The 10 bolt 1/2 tons have 4.56 gears and were already with this truck on 6 lug wheels. I do have a set of 3/4 tons with 4.11 but it’s a semi float rear and they are 8 lug. I know you could change the front hubs and rear axles to 6 lug but just going to put the 4.56 in it for now.Don't you need the ORD high-clearance cross-member to do crossover on 2" lift? Or did you go 4"? Now would be a good time to delete the rear 10-bolt. Do you still have that parts Suburban around? What gears are in those axles?
Yeah it’s finding the time to work on it. Prob can’t work on it for another two weeks or so. I may get a few things done tomorrow but not sure yet.It's coming along quick. But the large stuff does. It's the small stuff that takes so much time. Looks nice.
