What headers did you use and how was the fit?Rolled the truck out today to get a little bit done. Headers came in! Going to degrease it and get ready to be dropped in. Just need the proportion valve to run the brake lines. View attachment 464408View attachment 464409
Schoenfeld part# 1302ls1. They clear the frame but is close to the shift linkage. We had to move the linkage line up on the frame closer to the front of the truck.What headers did you use and how was the fit?
Looks fantastic!
Still has the opening next to the fender and the bottom towards the front core support. We had to cut some of the bottom out to make it fit level and clear the hood which also helped with air flow. It was also turned around to the driver side due to original 2007 being on the passenger side.I like the factory air box.
Where is the air coming in from?
