The datalog shot was one, real quick, dead stop, no brake, gas smash, trying to spin a tire.
Dry flat highway.
Were you not floored the whole time on purpose? You can also tell you are not getting 100% full throttle, even your full throttle varies a little, which shows its not against the stop.
Is your knock retard on? How is it setup? I turn that off on NA performance vehicles.
I would move your WOT A/F ratio target to 13, the LS usually will likely like that better and still pretty safe.
What is your WOT shift points set at? It's the top right button in your transmission window.
For some reason your 28 WOT timing didn't seem to take, it is showing 26.2 or something. Did you "smooth" it before you changed it? You may need to reset that one. It should read 28 all along the top 3 rows above 2500 RPM or so, it doesn't.
Other than that I wouldn't be making a bunch of changes right now, everything is close enough to run fine thus far. I would turn off the knock sensors for now and see how it runs and let it learn for a bit. I would also fix the cable so you are getting full throttle every time, whether you have to bend the pedal arm, or whatever you got to do.
What is your cam? I think I remember you saying your cam in a different cam thread somewhere, is that the one? Trying to see it so I can assess how important a converter change is.
I also think you should do a video of it accelerating so we can hear the engine.
