I'm not a fan of ball and socket either. I fought leaks on a couple different sets I've had over the years and they constantly loosened up even if they were double lock nutted. I ended up welding them both solid and that finally fixed it once and for all. The slip fit and those band clamps works okay but you need tight fitting pipes. A beed of high temp silicone under the seam on the clamp will seal them right up and still allows you to take them apart in the future. Or do V bands.
