LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
I had one of these breakers at both ends of my alternator line for the sub alt.
And the one next to the sub box kept tripping under heavy bass.
So I changed it to a fuse, to see what happens.
I'm fairly certain it was the vibration tripping it. As the front one never has :dunno:
Those emblems are a fairly thick aluminum. Stamped so the center is raised giving the numbers a definition.
And they're more like an anodized red than paint.
I definitely have to change the mufflers.
I loved the single 3" thrush welded I had on my old 'burnt burb'.
But they don't work for this setup. :dunno:
I'm going to try the dynomax super turbos it had, with these 'out the tail' pipes and see how that goes.
If I don't like it still, I'll probably swap in the FM delta flow 50's from the blue truck.
I want to find the sound I like before I get crazy tuning, as it could actually change some.
Stop and go is FAR better.
Still have to work on it a bit with transitions. But I'm going in the right direction :waytogo:
Tried getting some pics of the emblems.
Because I'm up here bored, finally working on the other rear door pod for the mid bass.
Also.
Need to get a gas type filler neck
This one ALWAYS bleeds fuel.
Always has since I went to gas... :dunno: can't remember if it did it before that.
New cap didn't help.
Vent maybe?
I figure the little wall and flap will help.
