M1009 Standard Shift Build(The Greatest Adventure)
Thanks! :waytogo:
I haven't been able to find weld on spring perches for the 14 bolt semi float. DIY has them for the FF. I don't know who else makes this stuff.
Call Kert, he will cut them for the tube diameter on the 14sf....
Also Ruff Stuff Specialties...
Hurry the eff up. I know you gotta be home by now. And I know you have a ton of pics
M1009 Standard Shift Build(drove my slow a$$ truck to colorado)
Almost Adam
I'm hoping to grab that 14 bolt semi float I posted up earlier.
Alright, I made it home and will update pictures and everything soon, but first things first. Chinese Food!
Thought you needed a 3.42 geared front?
My thought process at the moment is to pick up this axle. Get it all cleaned up and get the new spring mounts etc. on. Then I will run the 3.42 rears and see if I like them.
The last picture is the beginning of the creek I sunk in. As you can see the water is almost stationary.
