After building the 14 bolt I had some extra confidence in myself and set out to tackle the 60. This was definitely more challenging than working on a 10 bolt.
I think a ton of people are dreaming on the prices of these axles. I constantly see them on craigslist in DRW or SRW form for over $1000. Most have more rot and are in worse condition than the one I picked up from living under plow trucks or what not. If I had to choose between a used axle for $1200 and buying a refurbished one for around $2500 - $3000. I would definitely buy the refurb and I feel strongly that it would work out cheaper. Check out my parts list.
Unlike the 14 bolt build, where I felt like I could've been more frugal with the parts choices, every part I purchased for the 60 was the cheapest I could find. As it became obvious the buildup of this axle would be significantly more expensive, I spent extra time sourcing the least expensive parts available at the time. I don't think I could've saved much off my total cost if I were to build a 60 again.
If I had the means, I may have sourced a complete rebuilt axle from a known axle builder. The time involved in completely tearing it down, sourcing the correct parts, organizing, and rebuilding is definitely a commitment.
There are definitely a few parts in my list that bring the cost up that you don't get with a refurbished axle, like diff covers, u-bolts, steering arm, etc. But, I would've paid the couple hundred extra dollars for a refurb to save the time I've spent.
Parts List:
also ignore these wheel stud numbers for now... I could write up a seperate sheet for money spent on wheel studs
Specialty Tools: coming soon
Ignore the wheel stud part number for now... Those studs did not work. Apparently Solid makes 2 different front hubs for these axles with two different knurl diameters.
I think this list is missing trunion bearing cap seals. I just used silicone. There wern’t any seals there when I took them apart so I didn’t think they existed, but have since found people installing a paper seal similar to the kingpin cap seal.
I will say it again, make sure to check out the CK5 RockAuto discount code when you order from them.
Some part numbers refer to a “lower kingpin” and this is referencing the trunion bearing.
Also, the parts list PDF has additional part numbers to those listed in the video.
