I am debating if I really want to pull the trigger and commit to doing an LSx swap to my 87 K5. My 350 TBI is nearing the end. It is starting to run pretty badly and I know the time is comming to make a decision.
I really dont want to spend more than $2000 on the new engine. I know I can get a brand new crate 350 and all fluids and filters / parts needed for warranty validation for $2000. If I stick with the 350, my gas mileage will suck, I wont have a lot of power and I will be stuck running really expensive special oil.
If I can get the LSx swap (looking at a 5.3) done for $2000. I would be pretty excited. It seems like this will be kind of hard to acomplish at that budget. I am going to keep my 700r4 and NP208 for budget and ease of swap. I really dont want to mess with all the adaptors and machining to get an older transfer case to mate up with the 4L60E.
I know I need the 99-03 drive by cable motor. I can use my current tank and sender, just need a new in-tank pump. New style Drity Dingo mounts (non-welded). I am planning on the TV cable bracket form Bowtie overdrives. The parts I am most worried about is the wiring.
My buddy suggested finding the wiring off of a manual car as that could be easier to make into a standalone harness. Is there any reason that using the donor truck motor harness would be any more difficult?
Does it seem doable to have a quality, reliable setup with a 5.3L up and running in a reasonable amout of time for $2000?
If I do a stand alone harness setup, would I be better off to do a speed density tune? What sort of setup would work for the stand alone? How would that affect my 700r4 and T.V.
finally decided I'm just going to nut up and do the 5.3 swap.
