Yikes. Thanks for the heads up.
That would certainly do it. Although you don't really need the injectors and intake.
Well, looks like next week I should be picking up my full take out 5.3l. If everything is really as the place says, I should be out the door for $450.
After reading back through lt1swap it looks like I need to get the dakota digital vss adapter with my 700r4 for better drivability. Pn. - sen-01-4160.
Look into the "jags that run" speed sensor adapters too.
I want the best mileage / power / driveablity so it also looks like I need to keep all 4 o2 sensors? If I am running the exhaust like stock can I set it up for 3? Each bank gets one pre-cat then they share the cat and have 1 sensor after?
Run only the front two. The rears are only for sniffing after the cat to make sure they are working properly.
I am assuming it would be best to keep egr as well?
EGR is always up for debate. Although i cant think of a single swap that retained the EGR. I would say ditch it, but thats just what i and probably 90% of other swappers do.
The stock 87 tank doesn't have evap controls as far as I know. So, it looks like I can get rid of the wiring for that.
Yep. It can go bye bye.
Taking the top off today so I am positive it will fit on a pallet.![]()
