here is a pic at full droop btw
Well Gabe since your junk is running leaf springs clearly you are an expert on link suspensions.
This link is VERY helpful when it comes to a 3 link with 2 uppers.
http://www.pirate4x4.com/forum/showthread.php?t=548000&highlight=single+lower
well ill admit i dont know anything about building a 4 link or really wanna know..i wanted mine done right so i sent it up to 1-tonmudders shop...tangentdesignoffroad.com
shamless plug for thoose guys
ok back to the catfight![]()
that you did. i think linked is an awsome idea and works great, its just not for me at this time. my rig is for wheelin only. the only pavement it sees is the 15 miles to hollister hills. i have seen ppl linked and they have less flex than me. so for the time and money it costs, its not worth it IMO. now if you need 15" of lift, sure link it. but for 4-6" and a cheap build, why not use springs?
Well Gabe take into consideration you may also be wrong.
Im no noob when it comes to trucks musclecars quads etc etc either.
Im an ASE master tech by trade with nearly 20 years professional experience.
That doesnt make me an expert, but it doenst make me a dipsh*t.
Im not the only guy who has run this type of suspension with success.
http://www.coloradok5.com/coilover.shtml
And for the record Steve mounted his lower link to the stock trans/tranfer crossmember.
I mounted mine to 2 custom built 2x3 .25 wall X members.
OK I'll bite.
Gabe in your opinion what would be a wise choice for a link suspension in the front of a full size Chevy/GMC such as mine?
Stipulations being.....dual purpose rig wiht mechanical steering and coils.
muddybuddy can a well thought out leaf spring setup keep up with/out perform a link setup: yes
Ok, Radius arm suspension for the front...
here is a picture of basically what I would do as far as the links go.
note that there is good vertical separation between the lower and upper mount points. Also there is some triangulation gained by the upper mount being inboard of the lower mount.
The radius arms also mount to the frame inboard of where they mount to the axle. This produces an increased measure of resistance to side loads. That in turn reduces the stress that the panhard bar has to take.
gabe
Sure, but what's the anti-dive percentage? Its gonna be a big number.
Anyway, radius arms are not the greatest setup. If I were to design a front link suspension it would be a three or four link.
i know nothing about designing a link set up so im in way over my head here but what i do know is guys with thousands in there linked suspension have been out performed by my truck. might just be the driver. thats my 2 cents. back to the fight.
