MOTHER $%^&ING PIECE OF $*#@!!!!!!! update on freeze 12
Re: MOTHER $%^&ING PIECE OF $*#@!!!!!!! rant
Did the same shop do all the work? If so, then make 'em fix it. It's their screw up! /forums/images/icons/mad.gif
yes they did all the work but i'm afraid they'll screw it up again/more. /forums/images/icons/frown.gif
For what a/c work costs I'd make the shop fix it. /forums/images/icons/shocked.gif
Overcharging the system or adding the refrigerant too fast (slugging the compressor) can cause the valves to fail.
Problem is a lot of shops wont warentee their retrofit work if the compressor blows /forums/images/icons/frown.gif Its hard to prove its their fault unless they installed a new compressor made for 134a or freeze 12 which is mostly 134a anyhow .
You can probabally fix it yourself for a lot less than a shop will charge. I sugest converting to straight 134a and getting a compressor made for it.
Be careful buying a compressor from your local auto parts store. many of the ones they sell wont run 134a and are not warrented if you do.
Try these guys :
ackits.com
They have good parts and everything you need and are very helpful.
Here is a great board for AC questions and general info: Aircondition.com
There are a lot of very knowagable people there who can answer all questions you may be have
yeah i'm gonna do it all myself and just pay to have it charged. /forums/images/icons/frown.gif
