TheBeast_88K5
Banned
Currently deleting unnecessary wires, from the harness.
And, for ONCE in my life, all my nieghbors LIKE my vehicle!!!
They've all commented positively on it.
I don't get it, you're removing the manual transmission and pedals but going to put in an auto shifter that resembles one![]()
Look'n good with the rally's.![]()
Aaron (Dremu) was totally right.... That Argent Silver looks amazing.![]()
Well with this truck I wouldn't change much. It has a charm the way it is.Occasionally I have my moments. Also, repeat after me the mantra: "When in doubt, don't modify."
-- A
In other news, I got $60 worth of stuff, for $20 at Vato Zone.
And, I'm currently installing the heads...
Motor will be done in a couple hours.
It's just a factory rebuild, because the piston bores looked good, and everything else was fine.
Well, not completely factory.... I did do a little work to the heads.
Just a little.
Should still put down some great numbers.![]()
Umm.... Well.....
It had overheated a few times.
The push rods, and lifters got a little hot, a couple times.
There was some NASTY crap in the lifter Valley.
I mean FLAT NASTY.
The coolant ports were rusted shut.
I pulled about 1.5 cups of rust out of the block.
So much so, that I was a little afraid to pull it all the way apart,
for fear of a MagnaFlux showing me, what I don't wanna know.
Instead, I took the decent cylinder wall shape as a sign, and left it alone.
It holds compression, the cylinder walls are fine, the pistons look good...
I'm leaving it alone.
I'm gonna piece together a 427.
Not soon, but in ~year.
Then, you can have the 402 back.
This 402 should haul a$$....![]()
