yup...
I have a compression tester.
I also have 5gallons of race gas and a match
Sounds like valves
rats nest in the exhaust.
if you are getting oil pressure the cam is turning, if the cam is turning the crank is turning. I wonder if the exhaust is plugged up.
Exactly...even bent valves will build exhaust.
Are you sure it has pistons? Even if all the rings are bad it would have some air movement. Pull a head. I think the valve would have to be broken off to have nothing, or a huge hole in the piston.
Lies, I had 250 in a awesome peanut headed 454. It was a monster.
