. The inexpensive Blades and cut off discs are cheap for a reason. They dont last long.
Yeah, I cut the others to fit. They are temporary until I figure out what height I'm gonna go with. Im gonna go solid mount.What the?
Looks like you are using a body lift bush in place of the factory bushing, but the factory bushings are different heights. Did you cut the rest of the bushings down?
Its ugly but I was able to use scrap that I had lying around.
AND I dont have the tran/Tcase in position. Its about 5"-6" too low.
as opposed to the standard flat mount method. I was a little leary about strength so I ended up cutting the original mounting surface by about 1/3. I welded another 1/2" mounting plate to the 1/2" original plate I cut. This also gave me more than enough oil pan clearance.
I had my diff put a hole in my oil filter, so I am always looking out for those things.
