My stainless fabricator does great work with the TIG but I don't mind having him modify something if its going to sound better. I'll have him do some 3" v-bands on both sides this time which might make it easier to replace the next set of mufflers if needed.
If it necks down a little, thats fine but I just didn't want to go with something thats dual 2.5 muffler that restrict. Another thing I might do down is forced induction which means I need a good free flowing exhaust. Thats the biggest reason I did dual 3" and not 2.5"
Ok good to know. Thanks!
You are correct. If I had a single 3" with a more stock like engine, my Magnaflow would probably be fine. The cam it has seems to lope a little causing a fair amount of loudness. I don't mind a little at idle, just need to remove the drone and rasp at high RPM. It literally sounds like I have some Cherry Bomb glasspacks. And yeah, the bigger the body of muffler, the quieter it will be so I'm trying to find some big uns!
Ok good to hear. I was considering those or the 50 series. I thought the 70s were the quietest but from reading below, maybe not.
I looked into Thrush but the turbo mufflers didn't have the horseshoe thing the super turbos have for flow. How did you like the flowmaster 50? Loud? Quiet?
I looked those up and watched some videos of cars with dual exhaust and no cats. Seems a little loud from what I watched. Lots of these cars have some big cams though which I'm sure is not helping with being quiet. I wish there was a standard decibel test on every muffler produced. Idle and WOT test.
Ok good to hear. I think the single itself REALLY quiets things down which I can't do unless I want to change the entire stainless exhaust I just built. The dual 3" exhaust will make any muffler loud.
Great info. Thanks! Eventually I will have forced induction weather it be a supercharger or turbo. I realize the headers will have to go with the turbo idea but I didn't want to have to change the entire exhaust for any FI upgrade. Might as well go big to begin with. Anyway I will look into the flowmaster 50 bigblock. I do agree they aren't the best for flow. I've seen dynos with flowmasters compared to other mufflers and its not that impressive. That being said, I'm more worried about making quiet now so if I have to give up some tq/hp so be it.
Good to hear. I think I can fit them. My current mufflers are 24" body and 28" in total length. Thanks!
Thanks !I USE to have a big block but went back to a 406 SBC. My initial goal was twin turbos and make some killer HP with this Dart Block/AFR combo but had to scrap the idea after we signed on a new house build and I had to hurry to get the project running so the turbo idea went on the back burner for now. I do realize the smaller pipe helps but would rather not do that since it would require to scrap my entire stainless exhaust system. I think there are some 3" mufflers out there that will help.
I did come across this old article from a Pontiac site.
https://pontiacstreetperformance.com/psp/exhaust.html
Shows the mufflers flow and sound levels. It is pretty old so some are not being made these days. But look at the 17749 Dynomax Super Turbo. Seems to flow well and is quiet. That would probably be the offset/offset design that looks to have the best flow internally.
