That sounds like how mine is set up, guess it just looks too clustered to me. I just run factory gauges as well although right now I think the only one that works is the fuelyes i used the factory gauges i didnt see the point in blowing the money for auto meter stuff when i had a fully functional cluster sitting on my bench. but ill buy an auto meter tach for sure and for the switches i got rid of the heat a/c panel and put a ignition panel there and im also putting a panel where the vent came out directly above the heat a/c panel for lights fans and my mojave heater. what gauges are you using?
