Does Luckys taste like goatpiss?Got my slide hammer to fit under the gear, came out easy after it has been soaking in WD40 for a week.
The bearing is still stuck in there, we tried to hydrolic it out by filling it with grease and tapping the gear back into it. That didn't really do anything but the grease in the bearing helped.
It actually sounds quiet and good enough that I am just going to use it as is.
I hear you all...i'll play with it some more.
Mark i'm not sure what goat piss tastes like?
I might have to consult Fumes on that one.![]()
Try soaking it in evaporust for a bit.. won't hurt anything.
I'd see if you have a starter/generator shop locally you might be able to send it in to have it rebuilt. Those shops are getting fewer and far between for sure, but it would be right up their alley to clean that up and rebuild it.
Looks quite a bit better!
