need advice about my rear diff, video...
got the crush sleeve eliminator kit just know ill see how bad the rear is in the morning
well i went to harbor frieght to get a press and there out of stock,then went to northern tool and the harbor frieght press looks better than northern press witch surprised me. so i have to wait either way might see if summit sells one since i have to buy ring and pinion anyway.
ordered my press from harbor freight and now to order ring and pinion
gears are showing signs of wear and the pinion bearings are toast. i ordered my gears from summit just know for the rear. i already have the crush sleeve eliminator kit here.
i have my press on the way. now i need the installation kit and front gears going to put 373 front and rear and bearings front and rear carrier and pinion bearings. not looking forward to it. but will like the end result.
sad part is the rear gears are going to be Richmond and the front will be motive Richmond dont make a 373 for the d44 according to summit
i think its time i put my msd d6al box on, while i wait for all my stuff to come in. i have almost everything for it.
look what i got today, the tool (little curved thing in the last pic)looks funny but summit says they work and there not 500 bucks for it
that funky little curved thing is the pinion depth tool specifically for 12 bolt truck rear ends
Cool! I guess . .
I ain't never seen one of dem!
So I be lost....
Hahaha !
sad part is Richmond doesn't make a 373 for dana 44(for the front diff that is),according to summit. I will have to get motive gear or us standard
well i got the press just now and ill take some pics as im putting it together.and when its done
was easy to put together and everything made it surprisingly. i added a bol to hang the plates and i want to get another eye bolt to put the handle were i wont lose it
You need to get this done so that you can get to work on that old Chevy!
Is it a '55, '56???
Is it a '55, '56???
dad said i could have it was in my brothers name he started being a dick so i droped the issue.now dads gone im not getting it.so it will probably go to someone else cause my brother is lazy, wanted me to make it run for free. and that didnt happen.
well i got some parts yesterday, just wish it wasnt 34 degrees i would install my msd ignition box
summits 12 bolt truck install kit. saturday its forcast is 64 degrees so thats when ill do the rear
12 bolt has a crush sleeve but I think they have an updated preload crushless spacer that you can use opposed to that now. I know for sure there was one for one of the axles but just can not recall exactly. You might check with a drive train specialist and see.
