New LED Headlights for 89-91 models
Confirmed with seller, those are 4x6 in stock bezels, with LED bulbs. He says he didnt have to trim the bezels, as able to get them to fit. Does make the markers/turn signals look little on small side/disproportional, but overall not bad, and lots more options in 4x6
I tried H3 in the stock housing. The base is close enough it would fit with minor grinding, but the bulb is just too short. It creates a dark spot right in the center. :frown
I'm going to try an H1. The base will need modification, but the light source should be at the right depth. I pinged the eBay seller doing this for some shots of the beam pattern. :whistle:
I also noticed with parts I have on hand that some sealed beams have the H3-type base and some do not. I haven't dissected the latter yet because none are burned out, but it looks like a smaller hole, with just the 2 pins sticking out of some sealant.
EDIT: response from "designthatsign":
Only photos we have. not oem , there will be spots
If you look at the "H3" above, it appears that the light source is perpendicular to how it should be.
I got the H1s today and so far the conversion looks plausible. My test rig is a car battery sitting on the floor, but it doesn't look bad. I should take it outside tonight. The camera is all auto, but the LED is definitely brighter.
Guide Halogen of unknown age:
Sylvania H4703 with the LED aligned side-to-side:
The Wagners on the truck have the removable bulb. Only the 1 Guide I have is the fixed one, but it could be interesting to experiment on.
Here's the 2 bulbs together. The LED is really intense in the center, which I hope translates to distance.
I carried this prototype around last night. While lugging a car battery is inconvenient, I've decided the beam pattern is totally acceptable. There are a few anomalous outliers, but overall, it actually has more of a cutoff than with the halogen bulb (presumably because this bulb is projecting side-to-side instead of 360 degrees). Plus, having 4 lights spread across the grill will help average out the weirdness coming from 1.
Grind a notch and drill a hole, and the H1 fits the stock housing. It's probably OK to put a ring terminal in the screw for ground, but I'm waiting on real sockets.
I considered ring terminals on the mounting screw, but ended up with these H1 sockets from Amazon.
The 4703 and 4701 housings are identical except the bulbs are clocked 90 degrees different - at least on these Sylvanias. Either way, the screw on the bottom would be easier to tilt the bulb up in the housing like stock.
I drove with them last night and it's definitely an improvement seeing a white stop sign 1/2-mile away. Good enough that I'll be happy? Time will tell.
I installed these tonight. Couple of notes, I had to trim the supplied spade terminals a little to get them to plug into the factory plugs. The bulbs don't have any seal on them so I just ran a bead of silicone around them. Last thing is the cooling fan on the back of the H3 bulbs is ever so slightly bigger than the hole in the radiator support, all it took to make them fit is taking a wrench and bending the edge of the hole slightly.
The performance of these is pretty impressive, the beam pattern mimics stock closely and the light output is worlds better. With low beams aimed properly I didn't notice any glare standing in front of it and driving it the visibility is vastly improved. It went from dim candles to the power of the sun.20260906_195646.jpg
