DaveBrown022062
Registered Member
Hi truckers...... New member here, just beginning my first restoration project. I picked up a 1989 GMC Jimmy the other day that is generally very clean and in good shape with the exception of a few things. That's where you all come in.... I have a few questions:
1. Someone before me really messed up the removable fiberglass top by sanding it down, filling in the gaps between parts (that have since cracked), and did a hidious paint job on it. Does anyone have information on these tops like: do you know where I can find a replacement (don't see them on LMC.com)? Who made them originally so I might contact them?
2. I am thinking about getting a soft top so it will be easy to remove. I see companies that make full canvas "cap style" and another company that makes one that attaches behind the cab and is flush to belt line height. Do any of you have recommendations?
3. I have purchased $2,500 worth or replacement moldings, seals, etc. to be applied after the new paint job, from LMC. I tried to purchase the front bumper rub strip (the one with chrome accent in pictures), however, it is not available through them. Does anyone know where I might find these?
4. I am thinking about putting on a lift kit..... Not too high as I want to keep it below a standard garage door opening (it looks like 2" or 4" may fit). I am pretty fussy with appearance. I would like to have raised white letter tires still also. Does anyone have a recommendation on lift and tire combination?
5. I would like to add chrome, tubular, running board / steps on the side. Any recommendations?
Thanks in advance for any advice you can provide...... Dave
