84gmcjimmy
1 ton status
It's called FSM? thanks
joez said:Buy the chain, guides and tensioner from ENGNBLDR , they are cheaper than LC Engineering. Might as well do a cam at the same time, tooAs for cost, you can do it for less than $100, its just a pain to do if its your first time and you are unfamiliar with the motor. After you get used to tearing them appart, you get fast with them. I can go from a complete motor in the truck to just the block with rotating assembly in it in about an hour if i really bust my butt.
84gmcjimmy said:Is there a way to do a SFA swap without netting any lift? I want a solid axle for reliablility and because I like axles better then IFS stoof. Of do I have to get some lift??
http://www.yotatech.com/showthread.php?t=6715684gmcjimmy said:oh haha I feel like a dumbo.
Factory shop manual, so what would I search on ebay for? Toyota shop manual?
I tried just FSM and nothing related came up![]()
