There is one in that bucket that does resemble a header bolt, I suspect it metric a late model
I received this part number today, shanks fit yoke right, measured .310" and 1.475" length. Only half hearted attempt to place in yoke in installed origination, not sure I can get them in with yoke installed.This should be the retaining hardware ( the ones with the strap are a different animal ) - note the larger shank section of the bolt that puzzle pieces into the CV . Included a part number for reference.
They were damn difficult to work with in GM’s 68~76-ish front shafts.I received this part number today, shanks fit yoke right, measured .310" and 1.475" length. Only half hearted attempt to place in yoke in installed origination, not sure I can get them in with yoke installed.View attachment 449927
Thats amazing you found all that ! I looked through all my left over bolts, and none resemble these. Thank you for including the part #I received this part number today, shanks fit yoke right, measured .310" and 1.475" length. Only half hearted attempt to place in yoke in installed origination, not sure I can get them in with yoke installed.View attachment 449927
Yes, I had the unit installed, with shifter, pushed shifter to forward position, cut, pulled back, nope cut some more, check it until had 4h.Interesting. But you did cut the hole at the back abt 1.75" ?
Makes senseYes, I had the unit installed, with shifter, pushed shifter to forward position, cut, pulled back, nope cut some more, check it until had 4h.
That part # has more than likely been superseded over the years and this length dimension is what we are left with today.So the front shaft showed up today, I pulled the front yoke for a cleaning and test fit.
Definitely gonna pre install the bolts into yoke before yoke to output shaft install.
At first glance I thought these bolts were going to be way long,
While the threads will collect grunge, I don't see that they will hit on anything.
