Thats awesome to know ! Now i can look with an eye for that type bolt ! Thank you.As John stated yoke v/s flange styles - Wes has the ( around 1977+ there was some bleed over on some applications for a year or two ) Saginaw style CV and the other is the ole Spicer style.
If I recall correctly the Spicer bolts you are needing have an extended shoulder that feeds a little into the female CV component and helps kind of like a version of a dowel pin with threads for retention.
Might need to get some from a boneyard - does not need to be a Chevy; Spicer stuff was whored out to ALL domestic auto makers back in the day.
They look like what was discribed by wes, and are spicer, but they're sold out. Go figure.I am thinking that these are the bolts, I couldn't find w/o strap but you wouldn't need the strap.
This should be the retaining hardware ( the ones with the strap are a different animal ) - note the larger shank section of the bolt that puzzle pieces into the CV . Included a part number for reference.I am thinking that these are the bolts, I couldn't find w/o strap but you wouldn't need the strap.
Probably a few sets, partially organized so it will still take a day to dig them up.I’d bet @kennyw has some bolts.
Might be differences in years made ? - I guess the way to know for certain is look at the female side and see if it’s machined for the same depth/diameter as the shanks on either type of bolt hardware.Am pretty sure @tarussell post is what I am going to need. I found some $21. for 4 and 18 to ship yikes, not many places had them. I think the @HankScorpio might be the same as I posted with the straps.
Now to find a drive shaft.
I may have that too, I'll look at the shelf tomorrow.Now to find a drive shaft.
Might need to see if ya’ gotta a front T-case matching yoke for Wes as well to match the Spicer CV .I may have that too, I'll look at the shelf tomorrow.
I think you are right - look at the shank differences in KennyW’s spare hardware bucket. Keep it all matched up .yeah I need to remove that yoke and measure. Today I was checking it out some the yoke ears that the bolts go through are deeper than the front yoke. I think those long shanks are a match depth wise. Am wondering if these are .312 bolts that Spicer seems to differentiate from normal 5/16. There must be a reason.
The older 10-spline stuff and other makes of 32-spline yokes are common but I can’t say I’ve ever seen a GM sized 30-spline Spicer style yoke ? Not say’n they ain’t made - just never ran across one.
The later Saginaw style CV’s are really limited on rotational angle clearance and might be a little longer in length ( compared to the 1310 Spicer CV ) so that may have given you some trouble on the 700’s oil pan clearance.I have a clearance issue with 700r4/short output shaft np205. I believe the best results are going to be the older 1310r cv drive shaft.
I was going to change front output shaft and use the 77 np203 driveshaft and flange. till I really got a good look at my clearance.
Wes, I was thinking about the clearance issues you got with the 700R4 swap out from a TH350 and it got me wondering if the reason for GM hacking off the passenger rear corner of the TH350 is for clearance on a 4x4 application.I have a clearance issue with 700r4/short output shaft np205. I believe the best results are going to be the older 1310r cv drive shaft.
You may well be correct !!Wes, I was thinking about the clearance issues you got with the 700R4 swap out from a TH350 and it got me wondering if the reason for GM hacking off the passenger rear corner of the TH350 is for clearance on a 4x4 application.
The TH350 debut in 1969 and the same for GM’s auto trans mated to a T-case in the K/5’s, 10’s & 20’s making it easy for them to engineer it in at the beginning of its production - just might have been designed with that corner missing to make it fit damn near all things GM at the time, including 4x4’s….
Alright random thought and temporary high-jacking of this thread over with - y’all please continue with the regular scheduled programming.
Wes, im just seeing these pics: it looks like those bolts resemble header bolts ?
