Got a pretty good vibration going on at highway speeds, comes on about 45-50 and continues. U-joints good. My '83 K5 had a 4 inch lift when I got it, back to stock now, rear pinion and trans are parallel.
So, to diagnose, I removed the rear driveshaft and drove it in 4WH on the front shaft, it was smoother but still some vibes, especially when letting off the gas. Just today I removed the rear shaft again, started it up and put it in drive standing still. Vibration again comes on. So I think I've eliminated the rear end, rear shaft and u-joints. Revved up in park the vibration is gone, which is leading me to think it's either something in the tail end of the trans or the transfer case. With the drive shaft out I can move the output shaft in and out of the transfer case just a bit, maybe .050", and up and down just a bit too. With the shaft in there is a touch of up and down wobble but not enough to cause a leak.
Where to go from here? Is it worth pulling the tail housing off the transfer case to check anything? Oh and when I got this truck the transfer case was pretty low on ATF, over a quart iirc. But it works fine in all ranges and makes no other noises.
