DEMON44
Low-Tech Redneck
yes red. i torqued mine in the truck while it was on hoist. waaay easier than wrestling with it. stuff a rag in the gears and pull away. you can use an updated nut. theres a couple different styles of aftermarket nut for it. you don't have to get a new mainshaft. Chevy nv4500s are not known to loose the 5th gear nut. nearly as often as dodge nv4500s behind the cummins.
theres a couple reasons. the GM 4500 has a balancer assembly on the tailshaft. the dodge 4500 doesn't. the cummins obviously makes way more torque than any Gm engine. and when you lug down the cummins....... because you can...... the torque in the low RPM range hammers the OEM nut off.
theres a pinch nut style replanment, a nut with setscrews.... all require red locktite. I threw a couple tack welds on my replacement nut on after it was torqued. never an issue after that. this was in my dodge. not my chevy dually.
I made a socket from a wheel nut socket too.
