I'll buy the remains of that other setup for what you have into it if you want to get rid of it.
Martin
Martin
Martin
Martin, it is yours. I will send it along with the braces you sent me to copy!![]()
.Now, this is my first transmission so my knowledge is limited.Do you have the transmission in gear?
The best way to get that to spline up is to have it shifted into a gear, so you can turn the output shaft while trying to get it to slide together.
Martin
Yes I did. The one that came with the clutch.Did you use a clutch alignment tool?
