Alright need help again troubleshooting something on the blazer
Started running rough and found my brake booster had a vacuum lean and worn plugs. fixed both but in troubleshooting I noticed one bank is running a lot hotter than the other. This is measured on a l31 350 with long tube headers. Used a IR gun to measure. Tried doing a smoke test after fixing the brake booster but found nothing. Read this it could be caused by a leak on the valley side of the intake manifold. Before I dig into it wanted some 2nd opinions if this is even a problem and/or what else I should check.
2 267
4 285
6 310
8 300
1 430
3 500
5 400
7 458
2 267
4 285
6 310
8 300
1 430
3 500
5 400
7 458
