Yep.Guess I can do that with a IR gun?
Those numbers jive with expectations. The left cylinder head usually runs 10* hotter than anywhere elsewaited till engine was up to temp and thermostat was open and pointed ir gun to left and right of thermostat
passanger side 205~
drivers side 215`
on the thermo itself 200~
Yep. Not a flow issue. But the left should be warmer than that with the header Temps so far off.Those numbers jive with expectations. The left cylinder head usually runs 10* hotter than anywhere else
hey dont be holding out on us. lol
No input![]()
dual exhaust with dual cats, dual mufflers and a crossoverYep. Not a flow issue. But the left should be warmer than that with the header Temps so far off.
Check the heads just above the exhaust ports.
Is it dual exhaust out the back? Catalytic converter? Cross over pipe?
after cats before mufflersCrossover before or after the cats?
Cant be unless sequential efi . . Duel plane intake does 1/7 - 4/6 . . Then 3/5 - 2/8 . . So if 1 hole bank is hot its multiport or a weird problem .2 227
4 260
6 260
8 280
1 358
3 358
5 353
7 352
made some adjustments to the tune. its better
Maybe one cat is plugged up.dual exhaust with dual cats, dual mufflers and a crossover
If the manifold is hotter it should be hotter but not necessarily by that much but someLooks like I can unhook the exhaust. Can try that this weekend.
Would one be hotter if it was partially clogged?
