Should be a screamer when it's done.
I've been watching on IG. I love your attention to detail, I have so little patience for engine work. I just want to drop it in and turn the key.Torqued, primed, and ready to close up.
Did a dry assembly, everything went fine, and on we went to final.
Good day.
David
I just now got this. Ha! I was only a child of the 80s.Is the razor blade in the picture "party time"?
Martin
I’m similar. This is an every other decade venture for me, so it’s fun to indulge. It’s a whole other side of the brain from fab work.I love your attention to detail, I have so little patience for engine work. I just want to drop it in and turn the key.
All in all, I’ve thrown everything at this old IDI, and hope to make the most of it.
David
I love this. Never expected to see someone hot-rodding a 6.x these days, but I'm confident you'll do a good job.
It will end with the beginning of an epic 6.X build? CoolAll this hot-rodding kinda makes me wanna crank the boost on mine, to see what all it can do.
But my block is already cracked, so I'm pretty sure how that will end...
I still don't get it and keep looking for a razor blade...I just now got this. Ha! I was only a child of the 80s.
David
Good chit ain't cheap and cheap chit ain't good.Very True
David is good at marketing his brand as our local 'Gram Swill. Not that it makes that engine cheap.
But good engines aren't cheap, I know from empirical data
They’ll connect together and route to the upper radiator return.Are you just connecting the rear coolant "crossover" ports together? Or will they be connecting to something else?
Yep. No changes there.Are you pulling CDR off the top of the valve-cover?
Just an oil tap for the turbo.What is the extra port mounted in the middle of the Vee?
It’s there. I’m only missing the mirror. And the powder.I still don't get it and keep looking for a razor blade...
I figure I’ll only get to build this engine the one time. It’s a joy to be able to share the experience with my dad, and to fund the endeavor like he did 20 years ago with the 6.2.Not that it makes that engine cheap.
Your IG followers would have been disappointed had you done anything less uniqueThey’ll connect together and route to the upper radiator return.
David
David
It’s normal for them to be blocked off. There was no factory crossover at the rear.I’ve never thought much about the rear coolant crossover ports. On my 6.5, they are blocked off. It’s that the way it should be? Should they crossover? Or route to the radiator return like you’re doing?
Yeah, I’ve always been confused when folks setup a -8 or other large hose back there. There’s plenty of flow with a good pump, and a line that size isn’t additive to the systems ability to move water. That’s why I chose the 3/16” ID lines - large enough to purge trapped vapor but small enough so it doesn’t become a second upper radiator return.In regards to the rear coolant ports, I would leave them covered with the traditional block off plates.
Pulling coolant from that point in the system will create hotspots in the head.
David
I’m duplicating part of the steam tube design from LS engines to allow any trapped vapor in those hot back cylinders to escape and purge and hopefully not get trapped In the head. It’s all 4AN stuff. It’s an experiment to further improve the cooling system function.
David
Very high value.This to me would be worth all the monies. Enjoy!
I spent some time talking it through with the hummer dudes at rubber duck 4x4, and they’ve tinkered with it quite a bit and have some anecdotal experiences to share. I’ll make my best effort, and see if it’s snake oil or something else.I can't say that I've seen any long term reports good bad or otherwise from folks that have tried.
All that monster torque!Greg called yesterday. It’s a good thing I brought him the transmission. It was cooked.
Not exactly sure how it happened. It’s never been hot or flat towed.
David
