Yessir. The notch will be structural. Not sure if it’ll be billet or welded plate. I still have to draw it.Are you going to notch the front also to lower the fairlead?
2/0I'm curious, what size wire did you run from the batteries up to the front?
All those amps traveling 20’ needs huge cable. Both the power and ground make home runs all the way back to the batteries with 3 or 4 frame grounds along the way.
The cables get warm during extended winching or when I cranked to prime the fuel on the new engine, but that was it.
David
