Good on you David, but I'm still sitting over here waiting in the queue....
-G
-G
They work really good, love the set I have. To bad they won’t fit on the new radiator I have planned.I’ll be watching the derale install and performance closely. Might copy + paste.
These are the new SPAL brushless fans (OE Corvette and Camaro) in a one-off shroud. A catalog shroud won’t be that different, but they don’t have that setup yet. It’s in the worksAwesome. Is there a part #?
He probably figures he's got time.Good on you David, but I'm still sitting over here waiting in the queue....
-G
Those are nice. @Desert_K5 got a Camaro ss brushless fan when we did the genV swap. What are you using to drive the pwm?These are the new SPAL brushless fans (OE Corvette and Camaro) in a one-off shroud. A catalog shroud won’t be that different, but they don’t have that setup yet. It’s in the works
By the time my video hits, they should have more options online, but our wide stuff might be the last to get designed.
David
SPAL has a little temperature sensor/controller that I'll plug into the water jacket somewhere, and I'll have a manual mode running from the 12 channel switch pro.What are you using to drive the pwm?
NiceSPAL has a little temperature sensor/controller that I'll plug into the water jacket somewhere, and I'll have a manual mode running from the 12 channel switch pro.
David
I got mine back a week ago and it was a complete rebuild...He probably figures he's got time.![]()
For aftermarket, I’m told you can only source them through derale and other integrators as a part of a shroud assembly. They do nest in the shroud differently, but I think it’s mostly a capacity management tactic from SPAL.How does one source these fans? Is there a part number or are they take-offs from the camaro/corvettes?
CFM can be misleading, but these are rated a little over about 7000 for the pair at full froth. The big deal is a fans ability to drive a pressure change, and these are the newest version with a good bit of torque that should be able to draw a lot of air at static (how CFM is measured) and at speed, where a fan has to create a negative pressure inside the engine bay to allow air to flow over the cooler stack. I learned a lot from Tom and the group when we were chatting at SEMA, because I posed the same challenge, "I always thought I needed an engine fan for a diesel."What's the CFM rating? Would love to move to EFans, but haven't found any that follow enough air for the 6.5.
Color me intrigued, following these closely. I need to replace my fan clutch soonish and will likely do the water pump and move to the bigger dirtymax fan. But if these work I'd rather go this way.CFM can be misleading, but these are rated a little over about 7000 for the pair at full froth. The big deal is a fans ability to drive a pressure change, and these are the newest version with a good bit of torque that should be able to draw a lot of air at static (how CFM is measured) and at speed, where a fan has to create a negative pressure inside the engine bay to allow air to flow over the cooler stack. I learned a lot from Tom and the group when we were chatting at SEMA, because I posed the same challenge, "I always thought I needed an engine fan for a diesel."
These fans suck a lot, and keep luxury prerunners (really heavy heat-making machines) cool in the desert through a thick cooler stack. And so, I said, "why not try?" I'll be the guinea pig. Our deal is just product testing.
David
Your comment was on my mind yesterday. Leak free, and with very nice engagement into gear. Whew.Nothing like wrestling the heavy bitch into place only to find a leak and having to do it again.
