One ton leaf options
Could also move mounts and go with the newer body style 64" (think that's right) 1 ton springs.
The longer ones ride nicer, but you'd still have the weight capacity.
I thought ORD or DIY4x, maybe different one, had a kit just for those springs at one point. Because longer flexes batter too.
I was just going to suggest going to newer longer springs. I have 5" lift 64" springs in my K5. The longer springs will definitely ride better. Aren't 1 ton springs 56" and 3/4 ton 52" so you will be moving hangers anyways? I'm a big fan of air ride but running a light spring with bags will be the simplest option vs going to full link suspension.
Most 3/4 are 52 and most 1ton are 56 in square bodies. Other gens idk
have to swap to short bed tanks or rear only tank . the front hanger would be in the tank on 20gallon long bed tanks .
