I swapped out the dist. Module because I had one and the stuttering continued. Just left it on the trailer and bombed home the next morning.
At home, I unloaded the blazer and it ran fine, jammed down to our pond and back about a mile one way and no problems...let it idle for 15 minutes and shut it down...ran codes.
These are new to me codes, but I havent ran the scanner on this rig since i've lived here, so about 4 years...usually the egr code comes up.
The next day I ran it again down to our pond and crawled up a nice ledge and it started sputtering again...limped it back to the house. Swapped the fuel filter, same sputtering. Swapped the map sensor, same sputtering, swapped the entire TBI unit and same thing. Since I had all these parts laying around I figuered might as well...Im not sure where to start next, but the speedo and o2 sensor are next to be replaced, have to buy an O2, need to check the factory speedo cluster under the dash.
