Overkillz Dune Truggy Build
Prolly a good idea lol. Well we did put a 2" leveling kit and rear blocks in a buddys 03 silverado. I forgot about that.
PICTURES. I wanna do this to mine, and I wanna see how it looks. How hard was it to put on?
diggin it Adam....keep churning away at it!
Its just a key lift right?
Yah. You lossen the keys. Then wack the torsion bars out towards the front (gotta have the front off the ground lol) and the keys drop out. Lots of antiseize on the bar tips and insides of keys and it all slips together really easy. Exact same truck as urs brian. Then on the back you remove the old blocks and install the new ones. Super easy.
Got the driveshaft cut 3". Ground the weld off the yoke and slipped it out. Didnt realize they have a taper on them so we had to heat the shaft with the torch and pound in. Came out perty good if I do say so maself (for a coupla rednecks) :D
looks good Adam....I take it Nate is helping you tonight?
Just welded up a 15 ton crane hook for a buddies hitch. Now thats some Overkill Kustomz work :D
