I just got my AC changed to R134… 89 K5. Changed everything but the condenser … 95 degrees outside, the truck cools decent if moving…not so good standing still. I need to change to Parallel flow condenser. Does anyone know a direct fit… I guess the ACDelco 15-6960 Condenser is not a direct fit
This is what I have always said, from personal experience. I used to use my truck for work, driving it around for package delivery, similar to FedEx or UPS.
The AC would do fine if constantly moving, that would mean a higher volumn of air over that condensor, but would warm up to evap/swamp cooler temps when in heavy traffic, or city stop light to stop light type driving. The engine fan just did not pull enough air over it to keep everything cool.
I even tried adding an external electric fan to try and help it out, still not enough for some reason.
BUT, my mothers '94 that came from the factory with 134a system does great at any speed and outside temp, as does this '05 Avalanche, this one actually gets too cold at times to where you have to turn the vents away from blowing directly on you.
Even better was freeway driving, it would definitely get cold then.
I have played with AC systems in all my vehicles here in Arizona, the only conclusion I ever came to when trying to get older systems to work good, is set them up with the correct components with the type of gas being used.
134a freon will work in a system designed for r12, but it WON'T get as cold as it should/could be under normal circumstances, unless the condensor, mainly is swapped out for one designed for 134a.
