Hey, at least it's a step.
Dude this is a good looking rig! Way to go! I like that split with the matching bumpers, never seen it done like that, usually all are chrome bumpers..
I might us a conversion joint for now, and make the drive shaft right later. I would ask a shop how much to fix the shaft first. Probably did correct the length
Based on how you talk, I'm thinking you would be ok locked in the front. Are the splines the same?
It does become more difficult to steer. Are you crossed over?
It's weird, the pinion nut on mine was bigger than all the ones in the videos on how to change a pinion seal. In fact, I think the bolts for the yoke caps were bigger too. I did read where the 465 trucks had different u-joints, so we'll see, either way its no big deal.
Yes, I have 28 spline axles front and rear, so it should go in fine. I have push pull for now. Crossover would be down the road if I do it.
All this won't be done by Blazer Bash, so I'm thinking of putting the locker just in the front before then. Which would be weird, but better than nothing.
I just did this, it's a 1310-1350 joint and spicer makes one, I'll get the part number, if the joint on there now measures over 4 inches it's a 1410 if it's 3 5/8 and the caps are 1.88 then that's a 1350 the small side will be like 3 1/2 and the same cap size. No caliper grinding needed with the d44/10b 8 lug.
Why would you take the front apart (to install the locker) without also doing the regearing at the same time? That seems redundant.
Because I might take the axle out and take it in and have it regeared. I figure it's better if the locker is in there when they get it. I don't know why I figure that, but there it is. lol
It's called Moab fever. Doesn't have to make sense
), but if you're going to regear, have you thought about grabbing deeper gears than the 4.10s you have? Or is that just crazy talk?And not to be the voice of M.A.W. here (), but if you're going to regear, have you thought about grabbing deeper gears than the 4.10s you have? Or is that just crazy talk?
It's more of a compound malfunction, enlisting "I need this for Moab", MAW, and "Aw $&@% I need this too thrash"I thought Moab fever was doing a 36-hour wrenchfest the night before Blazer Bash.
If he gets Moab fever badly enough I'm sure the axles will get installed with time to spare.![]()
