Do you want the hubs from me?
Martin
Martin
I'll keep my eyes open.
I sold the same damn axle last year for $250 and it took me over a month to sell it!
Martin
Okay. I was going to keep the rotors (that's what I tore the axle apart for originally). I was going to send you the hubs and the backing plates. Do you need anything else?
Martin
I believe so.
Martin
Story of my life. lol. That one on the WFO site was perfect too, came with 4:10!!!!!
There is one listed here, but $675 for an 8 lug dana 44 with the wrong gears. Screw that.
Remember changing wheel bearings on a 3/4 burb, had to order them since they weren't the same
There are 2 versions of Dana 44 axles in which the later version you can still use the 1/2 ton spindles, but the earlier version you must upgrade to the 3/4 spindles
Not sure, remember the burb was an 84 10 bolt.Might just be the Dana 44
https://ck5.com/forums/resources/6-lug-to-8-lug-conversion.22/
Nows a good time to make sure, before he has a pile of puzzle pieces
the interwebs says you need a big bearing spindle if you're upgrading from a 10 bolt 1/2 ton axle. Apparently the later D44's are already big bearing based on that tech article I posted above.
