Summit has a inch pound torque wrench for 210
Whoever you borrow a bearing separator from has the torque wrench.
Maybe you need beer, like a case or two
Just remember, it's Horrid Freight stuff. Might break, killing nuns and children
Can you get a good bearing separator?
Do you have access to a press?
I usually change the carrier bearings, so that's nice.Does he need either of these? Or are they just nice to have?
Phil, I have a 4.10 10.5" gear set currently sitting in an axle that supports a trailer. Nobody would miss it if I pulled them out and mailed them to you...
Nah, he's tired of house workWell, I'd certainly use them, but I don't know if it would be worth the effort for you to get them out. I imagine it's pretty much a bitch to pull that apart.
Don't EVER ask that question where your wife can hear!Hahaha.
Yeah, that is true. I think mechanical therapy time will be making a comeback in the next few months.
At some point I hafta run out of house work , right?
If you guys do this, be a champ and keep the races to the side it came off. Shouldn't matter, but...One more thing I forgot...this set is missing its yoke. So I could easily separate the pinion from the housing. Even easier than I had first thought.
