You should probably just switch to building Ford's now!
Beam guys call it dirty hooker travel for a reason.I got the radius arms welded up and installed today:
At some point I'm going to box that in, but it's plenty strong enough for now. When I get to doing the suspension, that area might make a good place to mount shocks, etc.
Now that the beams are fully installed I decided to double check clearances.
Sitting on my temporary bump stops everything clears by 1/4" or so! It's hard to tell, but what you're looking at here is the pumkin fully stuffed. The light grey painted piece is the crossmember.
Since my axle u-joint modifications the other day, I've been wanting to test just how much travel that got me. Now that the beams are fully installed, I can check. I measured at the inner C at full stuff, then lowered the beam as much as possible:
Given that my u-joint bottoms out at 37.4*, my math tells me that each axle can drop 18* from flat (18* for each axle for a total difference of 36*).
At this point, I am 19" from full bump.That's pretty damn good news considering I was aiming for 14" of travel at the tires.
It's still possible something else will interfere, or the driveshaft won't be able to handle that much droop, etc, but for now I'm ecstatic!
I'll finish putting the axles back together tomorrow, then put the steering together and hopefully set it down on it's tires for the first time in months!
I was just thinking to myself after you drive that some bitch you’re gonna wanna coil and link your K5!You should probably just switch to building Ford's now!
I saw a dana 50 ttb coilover swapped K5 on Facebook a while back. Lost it though before I saved the clip.I was just thinking to myself after you drive that some bitch you’re gonna wanna coil and link your K5!
I’ve got a set of big coils from my son’s F350. It’ll be a bunch of $$$ for hiems and tube though.I saw a dana 50 ttb coilover swapped K5 on Facebook a while back. Lost it though before I saved the clip.
Don't you put that evil on me Ricky Bobby!You should probably just switch to building Ford's now!
It'll most likely be coils and a 4 link. Right now it is a 5 link with coils, but the links are pretty short and not a ton of separation on the upper links (hence the track bar link). It'll be tough to get a ton of travel out back unless I'm willing to cut into the cabin. I'm not completely opposed to it, but I want to keep as much interior room as possible, so we'll see.Just ttb swap everything! What are you doing out back to keep up with the new front end?
So are you going to use radius arms or something else?I got the radius arms welded up and installed today:
I'm not sure I understand the question.So are you going to use radius arms or something else?
If you are will you modify one side to get more flex?
Ah, I see. Yes, I build my own radius arms. The biggest issue with the stock ones is that they used poly (or rubber) bushings at the frame side. I'm using heim joints. Also, because I built them myself, I designed them to go lower on the beam end so they can stay below the frame rails on full bump.The original design had limitations on flex because of the design of the radius arms.
Are you using the same design or doing a different suspension system?
What about the attachment point on the axle side? Do you have 2 points top and bottom on both sides or one side?Ah, I see. Yes, I build my own radius arms. The biggest issue with the stock ones is that they used poly (or rubber) bushings at the frame side. I'm using heim joints. Also, because I built them myself, I designed them to go lower on the beam end so they can stay below the frame rails on full bump.
Yes and that creates a bind when you have a full flex.TTB radius arms aren't like solid axle radius arms. They are fully fixed.
When I get back from blazerbash and have it back up on the lift I'll have to take a video of the beam cycling. The only possible bind point is the heim joint at the frame side. The axle side can stay rigid because it is free to move through the arc the same as the beam.Yes and that creates a bind when you have a full flex.
The fix has been to make one side not fixed to relieve the bind.
Yeah, I assumed I'd need to do that, but so far I haven't seen any issues with binding there at all. My guess is the uniball is more for strength and durability. I could see a lot of hard jumps and extreme cycling of the beams wearing out those bushing fairly quickly. Luckily, the change to uniballs is pretty easy to do, so I'll just keep an eye on it for now.If it's too much for the pivot bushings it's common to replace the bushings with uniballs
