You should probably just switch to building Ford's now!
Beam guys call it dirty hooker travel for a reason.I got the radius arms welded up and installed today:
At some point I'm going to box that in, but it's plenty strong enough for now. When I get to doing the suspension, that area might make a good place to mount shocks, etc.
Now that the beams are fully installed I decided to double check clearances.
Sitting on my temporary bump stops everything clears by 1/4" or so! It's hard to tell, but what you're looking at here is the pumkin fully stuffed. The light grey painted piece is the crossmember.
Since my axle u-joint modifications the other day, I've been wanting to test just how much travel that got me. Now that the beams are fully installed, I can check. I measured at the inner C at full stuff, then lowered the beam as much as possible:
Given that my u-joint bottoms out at 37.4*, my math tells me that each axle can drop 18* from flat (18* for each axle for a total difference of 36*).
At this point, I am 19" from full bump.That's pretty damn good news considering I was aiming for 14" of travel at the tires.
It's still possible something else will interfere, or the driveshaft won't be able to handle that much droop, etc, but for now I'm ecstatic!
I'll finish putting the axles back together tomorrow, then put the steering together and hopefully set it down on it's tires for the first time in months!
I was just thinking to myself after you drive that some bitch you’re gonna wanna coil and link your K5!You should probably just switch to building Ford's now!
I saw a dana 50 ttb coilover swapped K5 on Facebook a while back. Lost it though before I saved the clip.I was just thinking to myself after you drive that some bitch you’re gonna wanna coil and link your K5!
I’ve got a set of big coils from my son’s F350. It’ll be a bunch of $$$ for hiems and tube though.I saw a dana 50 ttb coilover swapped K5 on Facebook a while back. Lost it though before I saved the clip.
Don't you put that evil on me Ricky Bobby!You should probably just switch to building Ford's now!
