Pigeon-Rat - Opel gambler build
1966 Opel rekord mounted to 1990 Nissan pathfinder.
I like that you started your sketch on the origin. Too many beginners just start drawing out in the middle of nowhere. Ideally, you will get all your sketch geometry fully defined. I would also not include the 3/4" holes in your first sketch as a general practice, add those as features after the base geometry so they are easier to edit as individual features. It is less critical on these simple parts, but the more complex you get, the more of a pain it is to put everything in one sketch when you start making adjustments later.
Thanks for the tips. I'll take any I can get.
afa starting on the origin goes, it's an ocd thing for me. :)
I got 1 swinger bracket done and swinger hung:
I had to notch the frame for the other swinger:
I also need to create a new swinger for this side with a slightly bigger offset. I'm hoping that the swingers being a little different shapes won't effect to much, so long as they are still the same length. I guess we'll find out together. :dunno:
As long as the imaginary line from mount to axle is the same length you will be fine, no bump steer on a jump
Got to work on the other swinger today.
Here is a pic of the setup I used to mount the swinger in the correct location.
I ran a 3/4 tube level off of the axle pivot bolt, then used that to locate the swinger. I couldn't think of a better way to do it, but it worked well enough.
Once I had the other swinger mounted, I hooked up the rest of the tu ingredients to see how it was going to look.
Feeling pretty good about hitting this 2nd major milestone.
I still need to cycle the steering and suspension to see if it's all gonna play nice, but it looks pretty good so far.
On the knuckle side, I decided to stick with tierod ends. After looking for something that would work, ended up just using chevy 1 ton ends. It'll be overkill, but what the hell.
I got my reamer out and reamed the knuckles to fit.
After how much trouble I had reaming the inner C's, I was expecting it to be tough, but the reaming only took a few minutes with the hand drill.
Now that I've got the tie rod ends in place, I was able to put some effort into the only complicated piece, the ds tie rod. Here it is at full bump.
It's turning into a complicated piece.
I still need to see if it works while turning, but it's more progress.
