Pigeon-Rat - Opel gambler build
1966 Opel rekord mounted to 1990 Nissan pathfinder.
I like that you started your sketch on the origin. Too many beginners just start drawing out in the middle of nowhere. Ideally, you will get all your sketch geometry fully defined. I would also not include the 3/4" holes in your first sketch as a general practice, add those as features after the base geometry so they are easier to edit as individual features. It is less critical on these simple parts, but the more complex you get, the more of a pain it is to put everything in one sketch when you start making adjustments later.
Thanks for the tips. I'll take any I can get.
afa starting on the origin goes, it's an ocd thing for me. :)
I got 1 swinger bracket done and swinger hung:
I had to notch the frame for the other swinger:
I also need to create a new swinger for this side with a slightly bigger offset. I'm hoping that the swingers being a little different shapes won't effect to much, so long as they are still the same length. I guess we'll find out together. :dunno:
As long as the imaginary line from mount to axle is the same length you will be fine, no bump steer on a jump
Got to work on the other swinger today.
Here is a pic of the setup I used to mount the swinger in the correct location.
I ran a 3/4 tube level off of the axle pivot bolt, then used that to locate the swinger. I couldn't think of a better way to do it, but it worked well enough.
Once I had the other swinger mounted, I hooked up the rest of the tu ingredients to see how it was going to look.
Feeling pretty good about hitting this 2nd major milestone.
I still need to cycle the steering and suspension to see if it's all gonna play nice, but it looks pretty good so far.
On the knuckle side, I decided to stick with tierod ends. After looking for something that would work, ended up just using chevy 1 ton ends. It'll be overkill, but what the hell.
I got my reamer out and reamed the knuckles to fit.
After how much trouble I had reaming the inner C's, I was expecting it to be tough, but the reaming only took a few minutes with the hand drill.
Now that I've got the tie rod ends in place, I was able to put some effort into the only complicated piece, the ds tie rod. Here it is at full bump.
It's turning into a complicated piece.
I still need to see if it works while turning, but it's more progress.
I got as much as I could out of working with the pvc, and it all looked good, so it was time to bend up the final tie rods.
The lower tie rods are made from 1.25x.250 round tubing. On the PS, I'm sure that's overkill, since the tube is straight, but on the DS, I wanted to make sure it would hold its shape under abuse.
Anyway, here it is:
DS axle is in full bump, turned all the way to the left.
Here it is all the way to the right.
Those are both worst case situations for that bent tube and it clears!
With that done, I started back on the radius arms.
I first bolted a tire on to see just how close to the frame it gets.
Turns out, not all that close. That means I was able to make a much straighter radius arm, which will help greatly with strength.
I think this is basically what I'm going to end up with. Lower tube is 2" .250 tube. Should be plenty strong enough for what it's plan on using it for.
I'm getting real close to having all the pieces in place as far as mounting the axles goes.
Once I'm satisfied that the steering, radius arms, and crossmember are going to work, it'll be time to take it all apart and build the final versions!
I took everything apart last week, and for the last several days, I've been working on building the crossmember in fusion360. Here is what I have so far:
I'm getting there, but it is not easy. The biggest problem is not having any great reference points to measure from. I'm bolting the crossmember to a curved part of the frame, the frame itself isn't perfectly vertical on the sides, and the car isn't level with the floor.
I was able to overcome all of that well enough when I'm just adjusting pieces as I put them on, but translating that to actual measurements on vertical and horizontal planes is tough.
Today I'm going to cut out the pieces I have so far in some 14g sheet metal to see if I'm doing this right before I make the final cuts in 3/16".
