Thomas Fournier
Central coast california
Ok I have a 350 SBC, bored 20 over eagle rods and balanced, 68cc performance iron heads w/ ARP studs edelbrock intake, crower beast cam full roller comp iron rockers, Sean Murphy quadrajet, Chevy H.E.I. w/ Accel coil and module w/ msd cap and rotor w/a recurve kit for 32 degree advance at 3200rpm. It pings like crazy even just light throttle. What am I doing wrong. It's set at 8 degrees primary and even w/the vacuum advance not hooked up it still pings. Yes it's on premium shell 91 octane. And the engine was built by a local reputable shop. Any input would be great cause I'm starting to just give up!
Thanks,
-Daniel
Confirm the timing marks are correct using a piston stop.
Thanks,
-Daniel
Causes for 'pinging' --->
  • Lean fuel mixture. [also lack of- or short- accelerator pump adjustment or action; low float level, no emulsion tubes (carbs)].
  • Over advanced timing - [you state it's not your problem].
  • Vacuum leaks - [usually worse at idle or 'tip-off' though].
  • Supercharger pop off set at 65# [or higher].
  • Over advanced cam - [did someone misinterpret the cam gear timing marks?].
  • Compression too high. [Pistons with high domes and an intrusion design, small cc heads, etc.]
  • Marbles in the combustion chamber(s)
  • Lack of EGR - [which cools the charge and prevents knocking/pinging].
  • Wrong heat range spark plugs - [are you using Champions? I dislike them intensely].
  • Low octane [I included this although you state it's NOT your problem].
  • Low coolant level; wrong thermostat [not likely these days - I use a 200F for my '86 383 stroker].
  • Bad/defective/missing/poorly working fan clutch or electric fan(s).
  • Low altitude - [carbs are not usually computer/mixture controlled for changes in altitude].
  • Intake valve(s) adjusted too tight and holding the valve slightly open all the time..
I know that if I take my 6000 foot altitude engines to sea level - they ping and knock badly.
If you left any of the computer in the system still, it should 'hear' the engine ping and start retarding the timing..
Connect vacuum gauge to manifold vacuum, then turn distributor to max vacuum inch...then back off 1-inch, and test drive. make sure the distributor is hooked up to manifold vacuum and not port vacuum.
