Poorboy's 91 Build... B52's 56's FUSH, SYE
let me know if you want help one night, i like to get stuff done, and not mess around.
Did i miss the WIN? did you get yor engine back?
Pretty pumped! Short block is done except for a cam. I bought a TBI comp cam but my builder talked me out of it. Working on what one to get now. Dropping heads off this coming week for rebuild. Then like earlier mentioned, the "not so expensive stuff that adds up to more than the big stuff". More labor than anything.....I think
Stuff to purchase:
Engine;
Cam
Water pump
Spark plugs
Alternator
Exhaust
Trans;
Cooler
Cooler fan
Driveline;
New drive shafts for clocked and SYE'd case
Axles;
Rear rotors
Rear calipers
Rear brake hoses
Front pads
Chassis/suspension;
56" front springs
63" rear springs
Shocks
Weld in/bolt on steering braces
Steering;
Tie rod ends
Cross over drag link
Ram
To do/Install:
All of the above plus...
2wd ported steering box
Hydro boost
Modded ps pump
Autometer instruments
Rear disc conversion
Make hydro assist lines
Wow this is looking like more than I thought....... C'mon power ball!
Go those already. I am on the look out for:
Steering Box braces
Hydro assist
Parts I have in the pile waiting for install:
2wd box
Hydro boost
Xj steering shaft
Autometer
Rear disc brackets
SYE
Clocking ring
Headers
FUSH
B52
Shackle flip
Shackles
Can knock off the list;
B52
Shackle flip
FUSH
Front and rear shackles
Thanks kgblazer
Sweet blazer, I actually have a pic of your blazer saved to my computer off of hefty fab works site because I liked the bumper.
Steering Box braces
2wd box
Hydro boost
Xj steering shaft
Autometer
Rear disc brackets
SYE
Clocking ring
Headers
FUSH
B52
Shackle flip
Shackles
After all this messaging and PM'ing on the trip out east...I finally clicked on your build thread...wow, nice work. I'm a little behind you though. Anyway, if you are looking for extra goodies for your rig you should contact the guy in Illinois that I gave you the contact info on. He told me he has a bunch of other stuff that he is parting out off of his rig. :dunno: It might be worth checking out while you are up there.
Apparently he built his M1008 and then rolled it and slammed a tree soon after. Now he is building an S-10 beast and has no need for the parts on his M1008 rig.
Good job, see you soon.
Well only a couple small things to report. Between those trips back east an getting caught up on side work, I've only had bits of time to do anything. Sent all my DIY4X stuff that I got from Keith out for powder coat. :thumb: I went and got the ford e-van pitman arm that is claimed to work with crossover steering. It's getting reamed to 1 Ton TRE right now. While that's out, figured I'd get the 2wd box drilled and tapped for hydro assist. All I have for pics so far.
It was an easier job than I expected.
space between your pics Geoff!!!!
good stuff man.
Lol I posted from my phone and this tapatalk app does whatever it wants with them!
So the fuse/relay box I got from the JY a while back.... Out of a early 90's Chrysler. I like this one for its simplistic layout. 10 large fuses, 10 relays.
It has the spade terminals in it for the relays. I can't find these anywhere:dunno:
I tried these with no luck.
Would rather have the correct style that locks in the right way. I will not butt splice all the wires on to what's there. Anyone have any ideas where to get the correct style?
You can reuse the same ones.
I usualy pull them out, open the ends, and put the new wires in.
Got all my DIY4X stuff back from powder coat I know... Not a very fun picture, but I don't wanna unwrap it till its install time
I understand that most of the time for hydro assist, we need the 2"x8" ram. Would it be ok to install a 2"x10" and mount it accordingly with an extra 1" on each end of the steering? (I understand my steering will limit itself before the end of the stroke) or will this create a problem with the extra 2"? Thanks in advance!
As far as I know yes you want your ram to bottom out around the same time as your steering. Not sure officially why but I am not sure I would like the ram having that much more space to continue to try and turn.
I think you'll want to stick with an 8" ram. That extra 2" of travel with 3000psi of pressure can surely damage a knuckle
Thanks! I'll have to have him measure it again. He claims it came off a 60, but it was a rock jock 60..
