Power steering mounting question.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Cadden, Sep 13, 2020.
  1. Cadden
    Cadden 1/2 ton status Premium Member
    Jan 28, 2020
    113
    42
    Oregon
    Like my custom brake line fitting there? I'm not even sure thats going to work but I couldn't find any other way to connect up extended brake lines
    Its got a 6 inch suspension lift
    6872xtc likes this.
  2. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    At least its starting to look more complete
  3. 6872xtc
    6872xtc make mine modified Premium Member GMOTM Winner
    Sep 16, 2008
    6,727
    6,455
    Palisade,Colorado
    Build(s):
    The power steering pulley having 3 grooves tells me that it's off of some other truck, possibly a medium duty. But if it lines up, then run it.
    I now see that you have a long water pump. This is only a problem if you use the factory fan shroud. The fan will be too deep into it and there could be interference problems with the alternator. I don't remember for sure.
    If you have it, don't forget the spacer on the long bolt going through the lower alternator mounting hole into the head.
    The brake line junction isn't a problem in my mind, as long as it is all sealed when you get to bleeding brakes.
  4. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    Seems to be good brakes are already bled and holding.
    I have an after market spacer but it doesn't quite fit between the block and alternator bracket. Previously they had just a piece of all thread for the lower bolt.
    As far as i can tell I don't have a fan shroud in any of my remaining boxes of parts
  5. 6872xtc
    Sep 16, 2008
    6,727
    6,455
    Palisade,Colorado
    Build(s):
    You may be able to cut or grind the spacer down, I can't tell for sure, of course. The idea of it is to help stabilize the alternator, obviously.
  6. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    Think it'd hurt anything to tap in in gently with a rubber mallet?
  7. 6872xtc
    Sep 16, 2008
    6,727
    6,455
    Palisade,Colorado
    Build(s):
    That's fine, unless it throws the belt alignment out of wack. They will take a little misalignment, but can be noisy sometimes. Too far out and you can toss a belt off.
  8. Wes Harden
    Wes Harden 1/2 ton status Premium Member
    May 28, 2005
    2,193
    2,291
    Southern Califorina
    That is definitely not the stock alternator, looks like 100 amp plus self regulated. 1 gens had external regs and at best 63 amp
  9. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    Oh yea, its a 140 amp one wire he gave me with it
    Wes Harden likes this.
  10. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    Its also got an HEI distrubtor.
    Id love to find some original seats as well as brackets. these things are hideous AND mounted ahead of the original seat mounting holes.
    Or a list of vehicles I can steal the seats and brackets from
  11. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    He already had it running with the newer alternator I know that much at least. I got to see it running years ago before he tore it down. Just wished I was there for the tear down
  12. Wes Harden
    May 28, 2005
    2,193
    2,291
    Southern Califorina
    140 is a good get, I went with 100 amp, and am wish I had the 140 may have to soon we'll see.
  13. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    He gave me the yellow top optima as well with it. And a bunchvof old distrubtors. I've got 2 rear drive shafts debating on selling one. Need to find a rear lift gate/hatch whatever u call it
  14. Cadden
    Jan 28, 2020
    113
    42
    Oregon
    Lossening all bolts allowed me to fit the spacer in with ease no hammer required lol
    6872xtc likes this.
