looking good. I was wondering if those body mounts were poly or rubber.
but it's out.
We start at 6AM and work till we absolutely have to stop, or nobody is getting any Vitamin V for a while. We have battled, rain, the parts guy missing it by only 1 number, flaky baby sitters, 1st graders with the flu, wives that knew WTF the budget was supposed to be a year ago... and it rained when we had to push it outta the shop to pull the axels out...
alot!
and we had to open up the hole for the fuse block but from my end the Painless wiring kit went in really smooth. I was doing the brakes while Justin did the wiring
. He did a lot of sottering and heat shrinking but didn't cuss much, did I tell you he's an electrician, a very well fed electrician.
Jeese over at HAD did an awesome job came in under budget and got them out the door earlier than promised. Jeese Rocks! Drive line brake went right in and hooking up tjhe original PB cable shouldn't be that tricky.
It was late, and I was trying to do everything
off my iPhone... But it's still sloppy posting. There has got to be a better way to do the pictures. When I preview the post I still only get to see text and them I put it up and. Violla, wrong f'n picture.
But other than that what do you think? Greg are you trying to say, "wow, you guys kick a$$!"
