If you have a large compressor and a air gun then go for it. Both sets will last considerably longer.
Well, I do have a compressor, at my buddys, but I`m considering OBA....iwaxmyjimmy said:If you have a large compressor and a air gun then go for it. Both sets will last considerably longer.
zero. Yep one tire balanced with no weight at all.Well, If this works out the way I want it to, I`ll have two sets of sweet tires. Why spend the money on a set of tires, that does decent on both terrains, when you can have 1 set that does sweet on the street, and one that does sweet in the MUD, if you have the storage room, which I have a few different plans for.MuddinManny said:x2 Mr. Ben. If the choice of tires makes you happy, then go for it! Many of us would like to run AT's on the street and MUD's for the trail, but storage and finances sometimes run that plan a muck (no pun intended). I say go for it!
Manny
Cool, lets see where this deal gets me. As for second tires, they will see some street miles, and I don`t think either of those could be had for the price of the LTB.gmc4cw said:no matter what you do you should get the pirelli's. $200 is a good deal if there is a lot of tread left. I have them on my blazer and I like them for the street.
as for a second set of tires. if you are truly only going to run them offroad them I would suggest Boggers or Iroks.
BIGBLAZE433 said:As for second tires, they will see some street miles, and I don`t think either of those could be had for the price of the LTB.
If you get them siped, does that void the warranty on them?blazinzuk said:I would probably get truxus mts over bfg muds. If I got the muds then I would get them siped they will last longer. I think the performance in the mud would be nearly the same, but I think the Truxus work a bit better on the street. The siping may equal this out a little. I called interco before ordering a set of truxus mts for a customer and they admitted they had a problem with one batch for sure but told me if I felt my tires were out of round to call them and they would take care of it. The truxus I did get used a worst of 11 oz to a best ofzero. Yep one tire balanced with no weight at all.
BIGBLAZE433 said:Well, for now, yes. But, a 14bsf is definitely in the near future...There`s one in a somewhat local junkyard, out of an 81-87. Not sure of gears, but, if its 3.73s, it`s a done deal, and its 8 lug, so I could go with Black Widow Perfomances kit, then I`ll have discs, and 6 lugs
If it can be had, maybe. But with only 33s, that is a little much, and I don`t plan on going bigger, so there`s no issue there...All depends on whats available...so far I can get a 14bsf (not sure what gears are in them) for $100.K5Greek91 said:why not 14ff. i dont think it cost much more, and you can buy the disc/ 6 lug kit for the ff too.. also you wouldbe covered in the future if you ever planned on going bigger
as for tire choices im sure you cant go wrong with a bfg mud or trxus
), and need to keep six lugs for my lack of funds. What is this six lug and disc kit for the 14FF you speak of? I must have it! If I can have a six lug 14FF with discs and 5.13 gears for $1000 or less, screw the six lug 14SF! I want to be able to go muddin'!
BIGBLAZE433 said:If it can be had, maybe. But with only 33s, that is a little much, and I don`t plan on going bigger, so there`s no issue there...All depends on whats available...so far I can get a 14bsf (not sure what gears are in them) for $100.
Every guy wants to go bigger!
I did it again! LOLbigblazer87 said:I'm not a big fan of steel wheels on my street truck, and I need 5.13's to return my power and then some. Trust me, I've crunched the numbers many times, and I still like the idea of keeping 6 lugs, either with a 14SF or this 6 lug disc 14FF that is spoken of. And I'm pretty set in my ways on this one...![]()
chevy wrangler said:bigblazer87 is the new old avery
