Alright guys, here`s the deal. My money situation has changed quite a bit, so its forcing me to make some changes, for the better of course. Now I know that this build has gone through ALOT of changes, but this IS the last one, and I want you guys to know that. No more changes, the plan is carved in stone. Please forgive me for misleading, or pulling anyone around here....With that said, here goes nothing.
Due to the financial situation I`m in, I decided that not only would this route be alot cheaper, but will also make for a better performing rig. Here`s whats happening. I know how some of you fell about used tires, but these tires have been looked at, and they are weared as even as can be. The tires in question are (4) 35x12.5r15 TrxUs MT Radials with about 65% tread, which I`ll be purchasing from a member on another board, for $250. Now I chose to purchase those for these reasons. As many have said, it would be wise to grab them because 1) They`re great tires! 2) Can be used for quite some time still and 3) Can allow me to use what extra money I have on other parts.
Now, axles. I will be picking up a front axle from a local member on the board. So, for $150, I`m getting an 8 lug 10b axle, Yukon 4.56 gears, MM hubs, all new ball joints/u joints, Lockright locker, for $150. I haven`t decided yet, but, I may either have a 14bsf built up, or get a cucv axle.
Now, that puts me at about $400, for tires, and a front axle. Now, I have a lead on some 15x8 8 lugs, which will put me at about $450, that is, if I decide to get a cucv axle, which would then put me anywhere from $900-$1000, which I can safely say I have.
Now, as I said before, this is the LAST change that will be made in this build, and I`m asking for forgiveness, from everyone that I`ve mislead and/or dragged around over the course this thread has taken.
On the flip side, my uni strut is ready to go in. I`ll be getting some smaller unistrut which I can use to make my new console, as well as tie the two struts together on the underside of the floor. I`ve got the Lokar situation all figured out. I will be using it, but not before a few questions. My hump is not removable, is it possible to install the bracketry for the lokar underneath, or would it be worth making my hump removable? I`ve figured out the reverse light and NSS out, so that`s all set.
Let me know what ya think, guys.
