Russell submitted a new Build:
Project Caddy - 03 Escalade Build
Read more about this build here...
As some of ya'll know, I daily drive a 2003 Chevy Tahoe Z71. I picked this truck up off my folks a couple years ago because my old 2012 Duramax was constantly at the dealership getting fixed and I needed something to drive while it was there. Despite having a new 2014 to replace that truck after it burnt to the ground which far more reliable than it's predecessor I've come to really like the little Z71 and actually drive it far more often than the truck. It's a very comfortable luxury vehicle with heated seats and a kickin' sound system in it.
My parents bought this truck brand new in 2003 and it was my mom's daily driver. She decided that she wanted to be more green and was going to start driving the car more often so it pretty much just sat in the garage. It only had around 80k on it when I bought it from them and have around 117k on it now.
For the most part the truck is totally stock. The truck is fully loaded with every option available in 03, except for the rear DVD player and the sunroof, because Dad didn't want to spent the money on those two particular useless featuresBeing unable to leave anything stock for long I modified an ARB bumper intended for a Toyota 100 series Land Cruiser and installed it earlier this year as the front bumper was getting rotten and was starting to fall off.
That's about to change.
I've recently acquired a 2007 F350 Dana 60 high pinion axle. It came complete with the full suspension including the frame side mounts (actually came with the whole front frame chopped off just behind the radius arm mounts), all the steering including the steering box, the brake lines etc.
I'm not sure how many folks here are familiar with the newer Ford D60 stuff, but it is incredibly beefy. Like, it makes an old Chevy D60 look like a Jeep TJ D30 kind of beefy. They come stock with 3.75" axle tubes which are 1/2" thick and 35 spline axle shafts. The knuckles are big enough to fit 1550 axle shaft u-joints which allow for an impressive 45 degrees of steering if you feel so inclined as to cut down and re-spline a set of F450-550 Super D60 axle shafts. They run ball joints and unit bearings but both are massive and are far more reliable than the older stuff was. This axle has a 7000lb weight capacity which is far beyond the 4 or 5k the older D60s are rated for and as a result full on mechanical breakage is rare. The unit bearings are equipped with wheel speed sensors which play nice with Chevy ABS to boot. Warn has...
Jason Ginn put his Mother Lode build together last year and has been wheeling it throughout the mid-west since. His Yukon has a 79 D60 front and a full float 14 bolt rear. Both axles are fully trussed and fitted with the very best of axle shafts, brakes and other parts. It has a custom 3 link suspension front and rear. The steering is done properly with the box pushed forwards several inches. It has King 2.5 coilover shocks and air bumps. It was tuned at KOH by some of the best shock tuners in the business and proved itself one of the fastest grocery getters on the lake bed. When the Yukon was totaled, it was lawn darted into a sand dune and flipped onto it's lid. The body is toast, but the frame and suspension is unharmed.
